J7 Max problems After Dec. patch
(Topic created on: 01-02-2018 10:38 PM)
Dkay
Galaxy J
1. Touchwiz Home is not stable
2. Notification panel flicks notifications
3. Gallery lags a lot
4. keyboard frezzes sometime while replying the message in notification panel
5. Weather ap takes 7 second to open
6. More Battery consumption than usual (worst)
7. Slow charging like never seen before
8. Lots of Bugs
Comment ur problems in J7 max after Dec. security patsch update
6 Comments
Galaxy J
mine is working fit n fine
Rajatbisoe
Galaxy J
the last dec patch contain lots of bug
darshanreddy
Galaxy J
slow charging
admin_
Galaxy J
Thanks for being with Samsung and for sharing your concern. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
Be sure to hit ♡ when you find an answer that works for you.
Hedan
Beginner Level 3
Galaxy J
battery discharged suddenly from 68 to 2 percent.896fc6de-ac45-4aec-aaa0-9be7787f15df.jpg
siddhanta
Galaxy J
My keyboard not working properly like when I am pressing a key some other key gets pressed automatically .
