NachiketGholap
09-18-2019 11:21 AM in
Galaxy J
3 Comments
Not applicable
09-18-2019 01:26 PM in
Galaxy J
uninstall all garbage apps that you dont use
ItsNiraj
09-18-2019 01:29 PM in
Galaxy J
Bro I assume you must be knowing that battery does wear out over a time. Given you are using J7 16, must be more than years old and still last 20hrs is pretty cool.
nick311
09-21-2019 09:51 PM in
Galaxy J
well its not about how old ur device is ok ...its depends on how much apps working or running while u screen is off...and i think lock screen story which we got with the last update is the most useless feature it consumes power so 1st turn it off and check your data cable may b have the problem with ur data cable ......and buy high speed data cable 2.4...
