Battery Drain Issue
(Topic created on: 02-19-2022 12:50 PM)
shrikantsteelindia
Galaxy J
I am Mansi from Shrikant Steel Centre, working under sales head. I am using office phone "Galaxy J7" since 6 months & its battery get drain within an hour after charging to 99%. Can you help me to sort this out?
2 Comments
siyaram1998
Galaxy J
Change your battery
cs_member8
Galaxy J
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
