Problem with C9 pro
(Topic created on: 11-09-2018 07:22 PM)
Ishan23
Galaxy C
Galaxy C9 pro screen flickers on low brightness
Model : SM-C900F
7 Comments
Shiv9564
Galaxy C
Have you checked it in manual brightness?
You should go to service centre.
wasee
Galaxy C
Did it come in contact with water? either way have it checked at a service centre
Ishan23
Galaxy C
@Shiv9564 Yes, when I put the brightness to as low as 20%, it starts flickering.
Ishan23
Galaxy C
@wasee No way, It's fully cased from the date of purchase.
admin_
Galaxy C
We apologize for the issue facing in the device. We would like to inform you that kindly follow the steps below to resolve the issue:-
1 Adjust the brightness of the device then check (Setting-->Display-->Brightness)
2 ""Disable the “Show Screen Updates"" option in developer options or completely disable the Developer options.""{(Setting-->Developer options (If its available & highlighted)-->Show Screen Updates)}
3 Check third party applications if downloaded recently. Post which check in Safe Mode, if the issue still persists.
4 If the device is in Safe mode and the problem still exists, we would advise you to create the Data backup & Factory Reset the device.
5 Periodic Software Update through FOTA, SMART SWITCH or Smart Tool is intended to resolve the issue as well.
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
deepakvashya
Galaxy C
nice
Galaxy C
super post
