Samsung F62 Battery Drain Problem
(Topic created on: 05-16-2021 10:53 PM)
JawaharF62
Community Guidelines
Samsung F62 🔥
 Can someone let me know if you are facing Battery drain in f62?
 I charge my battery upto 100% fully. But the battery is automatically getting lowered from 100 to about 97 or 98% just in 10 minutes even if I do not use the phone.
 Does any of you face this?
 And how's the battery backup you are getting from this smartphone?
 Overnight it drains 10-12% charge
 I have purchased last week, on the first On its showed update,I have updated, then I used to continue for 4 days ,after that I have factory reseted the mobile because of battery drain
No changes
is there any solution to save battery
11 Comments
zeus90
I use vi 4g and Jio 4g for calls and Jio 4g for data. Will that cause more drain as both are 4g?
Municifient
Yes brother i am also getting the same problem i dont know why samsung placing bugs like miui????
