Samsung a34 heating and battery drained problem
(Topic created on: 07-19-2023 02:21 PM)
Dhinesh_01
Community Guidelines
I recently bought samsung galaxy A34 .it has been 15 days and I'm facing heating issue in normal usage. battery drains very fast 1% drain in 3, 4 min or in 5min for sure!on screen time. switched to samsung but you disappointed me.samsung just focusing on quantity of sales not on quality samsung loosing respect so I'm worried 😟 any solution I don't know what to do
9 Comments
imanandkumar
Go to service center
Dhinesh_01
They tells it's normal level what I should do
imanandkumar
Purchase from where
Dhinesh_01
Darling shop
imanandkumar
Then go to shop & say about problem
Dhinesh_01
They said go to the service center
SanketSakpal
If you do not wish to use 5G data service then switch 4G network
Dhinesh_01
I'm using 4g bro
cs_member10
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application>Support>Type your query>Ask a question/Tap an error report>Send)
