Samsung F62 Battery Drain Problem
(Topic created on: 05-16-2021 10:53 PM)
JawaharF62
Community Guidelines
Samsung F62 🔥
 Can someone let me know if you are facing Battery drain in f62?
 I charge my battery upto 100% fully. But the battery is automatically getting lowered from 100 to about 97 or 98% just in 10 minutes even if I do not use the phone.
 Does any of you face this?
 And how's the battery backup you are getting from this smartphone?
 Overnight it drains 10-12% charge
 I have purchased last week, on the first On its showed update,I have updated, then I used to continue for 4 days ,after that I have factory reseted the mobile because of battery drain
No changes
is there any solution to save battery
11 Comments
Didnt notice such thing in my F62. Over night draining is very minimal provided we are switching off data, location and close all apps
JawaharF62
I have swithed off everything but it gets drain,even I have tried power saving mode overnight it drain 10%
RajaRP
facing same issue. I have cleared wipe cache partition too. but still loosing 8% idle battery drain at night.
JawaharF62
Yes , I too done Wipe/factory reset yesterday but no changes
Even i have using single sim bsnl 3G,not even a 4g
I have turned OFF wifi,NFC,auto sync,location,
BATTERY 🔋DRAINS 7% for 8hrs without any usage at night
JawaharF62
Use bsnl 2G it drain 3% ,if i use 3G it drain 10% for me for 8hrs
Sunnypareek
Sab kuch karke dekh liya ji koi **bleep** nhi h
cs-member13
Expert Level 4
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
zeus90
Same issue I'm facing after just getting the phone. Did you find a solution for this yet or is it still the same?
JawaharF62
Yes, If i use bsnl 3g it draining 10% overnight, if Jio 4g it drain 3-4%
