charging problem
(Topic created on: 05-25-2020 11:07 AM)
PUB
Tech Talk
I have m31 from past 2 days it's charging too slow that even charging for 15hrs it has reached only from 0 to 75%, what is the solution???
3 Comments
Arth1
Tech Talk
only solution is to power off tour phone and charge. This is problem with the latest update in each samsung device. Hope they will fix it asap.
3sh
Tech Talk
Same problem here...!!!
Samsung_Support3
Tech Talk
Dear Samsung Member,
We apologies for your inconvenience. Please perform the below mentioned steps to resolve the issue:
1. Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged then kindly visit your nearest service center to get it replaced.
2. Check charging, if rating is 15W or above. Kindly try to charge the device in a non-inverter socket.
Note: Kindly open Device care from Settings > Battery > Please tap on 3 dots(more option) at the top right hand side > please select settings > enable fast cable charging.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
