charging problem
(Topic created on: 05-21-2020 02:28 PM)
nandu78933
Tech Talk
My new samsung samsung s9 plus phone taking too much time to charge ..its nearly take 3 to 3 30 hrs in fast charging mode also ..can i have any solution for diz?
Samsung_Support3
Tech Talk
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
1. Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged then kindly visit your nearest service center to get it replaced.
2. Check charger functionality, try to charge your device with some other charger or use your charger to charge some other device.
3. Check charging, if rating is 15W or above. Kindly try to charge the device in a non-inverter socket.
Note: Kindly open Device care from Settings > Battery > Please tap on 3 dots(more option) at the top right hand side > please select settings > enable fast cable charging.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
