battery problems in my samsung a50s cell. Battery decreases very fastly.
(Topic created on: 10-07-2020 10:39 PM)
1ak
Beginner Level 4
Tech Talk
How solve my battery problem????
3 Comments
Ehsank
Tech Talk
do these settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
Nikhilknp
Tech Talk
What is your SOT
Samsung_Support3
Tech Talk
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
