Resolved! Solved
#battery drain issue
(Topic created on: 11-15-2019 08:04 PM)
sona151625
Tech Talk
I have been facing battery drain issue for 20 days..in my m30 phone.
Can anyone tell me how can I solve this issue...
My phone doesn't battery backup for one day.
9 Solutions
ShiveshSehgal
Tech Talk
My advice to you is to turn on battery saver mode for now .
Tech Talk
check which app is running in background. multiple apps running in background can cause battery drain quickly you can use device care from settings
akashreturns
Tech Talk
best solution is goto
1.recovery mode
2.clear cache ( make sure not data)
3.reboot
Tech Talk
Could you post your battery stats graph available in battery section of device care?
ATANUROY
Tech Talk
ist check the apps which are draining the battery specially the 3rd party one...2nd change settings optimised....3rd put all apps to sleep..charge thr phone under standard mode will get...the sol....
Tech Talk
Get your battery to 1% and charge it upto 100% in a single stretch.Then check device care-battery and check the estimated battery life.Then,under the same battery section which displays screen on time and the app usage,click on each on and disallow the app to run in background.Use your phone frugally and let it reach 1% and don't recharge till you've reached 1%.Then please post the battery stats again.If the problem persists, let me know.
saikodali
Tech Talk
Using Battery saver mode will be the better way for now.U can reduce battery usage by
1. Decreasing screen brightness
2. Unistalling third party apps
3. Cleaning device ram
Tech Talk
Set the phone to work in optimised mode
Samsung_Support1
Tech Talk
Hi there,
To resolve the issue please follow the troubleshooting steps provided in the given link: http://www.samsung.com/in/support/skp/faq/1101689
We can guide you further if the issue persists after performing the specified steps.
Regards,
Team Samsung Members
23 Comments
ShiveshSehgal
Tech Talk
sona151625
Tech Talk
battery saver mode... I do on this mode when battery percent below 30% but I don't use this mode when 50% above... could u tell me any second method?? Is too much issue in battery backup.. doesn't backup for one day despite having 5000mah battery... I have to charging 2 times times on one day.
Tech Talk
sona151625
Tech Talk
I have checked which all apps running in background and also put to sleep mode.. however battery doesn't backup for one day..
akashreturns
Tech Talk
1.recovery mode
3.reboot
sona151625
Tech Talk
Thanks I will try and see how the battery backing up..
Tech Talk
sona151625
Tech Talk
plz check and tell me how to fix issue 😥🙏
Tech Talk
