Heating & fast battery drain issue in OneUI 8 ⚠️
(Topic created on: 09-26-2025 02:15 PM)
Mr_Desai
Tech Talk
Does anyone user having Heating & fast battery drain issue after OneUI 8 stable update ?
5 Comments
DevDKJ
Tech Talk
No
uk5122
Tech Talk
Yes i have same problem
cs_member10
Tech Talk
Dear Samsung Member,
As per your concern, we would like to inform you that the latest software update has been developed to enhance both the performance and stability of your smartphone. This update has undergone thorough testing at various stages to ensure reliability.
While we acknowledge that issues can arise due to individual usage patterns and other factors, we want to assure you that our dedicated customer support team is always here to assist you in resolving any concerns that may occur post-update. As of now, there are no reported issues with Samsung devices.
Meanwhile, please perform the below-mentioned troubleshooting steps to resolved the battery drain and heating issues, if you are facing on your device.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps).
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
krishnaRajak
Beginner Level 4
Tech Talk
Galaxy a55 5g me android 16 kab aayega
rikivs
Tech Talk
Yeah I'm facing this after the oneui 8 update in m35
