🔥 A34 One UI 7 Update–Fixing Battery & Heat Issues❗
(Topic created on: 06-20-2025 12:09 PM)
Musabbir_Zone
Tech Talk
🌡️📉 *Facing Heating & Battery Drain After One UI 7 on Galaxy A34?
Hey Members! đź‘‹
After updating my *Galaxy A34* to *One UI 7*, I noticed:
🔋 Faster battery drain
🔥 Slight heating during regular use
Here’s what I tried and it helped:
âś… Wipe Cache Partition (Recovery Mode)
âś… Updated all apps (Galaxy Store + Play Store)
âś… Put unused apps to Deep Sleep
âś… Turned off Background Data for heavy apps
âś… Disabled Always On Display & Edge Panels
âś… Used "Optimize Now" in Device Care
âś… Sent error report via Samsung Members > Support
📌 *Pro Tip:* After a major update, the system may take 48–72 hrs to stabilize.
If you're facing similar issues, try these steps and share your results!
Let’s help each other out 💪📱
2 Comments
JithinAjith
Expert Level 3
Tech Talk
Update Google Play Services
Update all apps
Solaiman_Zone
Tech Talk
Thanks
