Smart View Issue
(Topic created on: 11-01-2019 10:46 AM)
Nish27
Tech Talk
My Samsung M30s cannot connect with my Sony Bravia TV through smart view
8 Comments
chiron
Tech Talk
change your tv name in settings or your mobile name and then connect.and also see settings in your tv and there you will find smart view or screen mirroring(crome cast)go inthat and then follow the settings then if it gets connected one time nxt time automatically it will connect as you turn on smart view
Nish27
Tech Talk
how do I change name or reset?
RAVI1000
Tech Talk
if your TV is Sony bravia smart TV then try to reset it and connect it again. my m30 has same problem I reset the TV and it get connected. 😀
Nish27
Tech Talk
what should I reset in TV and how?
thanks friend
RAVI1000
Tech Talk
if your TV is smart TV
and if your it is android TV then. download Google home app and connect.
chiron
Tech Talk
you can change it in your tv settings or in tv settings you remove your device name,you can remove in the connected devices, there you remove your device and then again connect it
chiron
Tech Talk
and snd picture of your tv and phone while connecting,you just take a screenshot
Nish27
Tech Talk
okay, thank you
let me try and I'll get back to you
actually it was connected earlier but now it not get connected
