Charging problem
(Topic created on: 04-25-2020 10:53 AM)
vivekkalsi
Tech Talk
A50 have charging problem  ...
need some help
2 Comments
Bubluu
Tech Talk
Check for the following reasons:
1.Charging USB cable may be damaged.Try with other cable
2.Try to charge your device with official samsung charger
3. Charging port may be damaged.
4. Battery may be damaged
5. Weak power source
If above reasons are not the issue i think you sholud wait and visit a service centre after this lockdown.Hope it helps you
Samsung_Support3
Tech Talk
Dear Samsung Member,
1. We always recommend to use genuine Samsung charger for charging your device.
2. Check physical condition of USB cable, if any tear or bent please replace it with the new genuine one.
3. Avoid usage of mobile phone during charging as it consumes a lot of battery.
If issue still persist or for further assistnace, kindly register your concern in Samsung members app (Samsung Member > Get help > send feedback > Ask question/Error report)
