Battery drain issue
(Topic created on: 01-06-2024 07:27 PM)
pawan56
Tech Talk
Hi there I purchased s23 fe on 25 Dec. I'm suffering from battery drain issue . The screen on time is just 6 hr. Is it normal ? And what to do for the same?
3 Comments
swapan1997
Tech Talk
Yup ..it's normal ..my s22 ultra gives me around same 6 hours sot ..
Tech Talk
My S22 Ultra giving me 3hrs of SOT🥲.
cs_member10
Tech Talk
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps by a given link to resolve your issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
If the issue still occurs, please visit the service center for a physical device inspection. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
