Battery and Heating issues
(Topic created on: 10-25-2020 12:39 PM)
HRIDAIKM
Tech Talk
I was Honor play user before I switched to the galaxy S20+. The 3750 mah battery was sufficient for a daily usage with mild gaming.
But S20+ is only running till the evening with the same usage. Ya, I ran on 60fps hd+ res and with adaptive brightness off and at 30+ battery.
In Android 10 (out of the box os version) the phone used to heat up with basic usage also, now its fixed but still manages to heat up with continuous usage.
7 Comments
Not applicable
Tech Talk
did you join beta program?
HRIDAIKM
Tech Talk
Yes
Not applicable
Tech Talk
then it's quite possible bro ...because still it's beta not officially optimised software..so anything malfunction can happend
HRIDAIKM
Tech Talk
Ya, that's the point of beta and let's hope this issue fixes in the stable version
Not applicable
Tech Talk
yes it will fixed.... because we are seeing this from pie beta and Q beta program
HRIDAIKM
Tech Talk
Nice.
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
For heating issue details follow the instructions provided in the link given below:- https://www.samsung.com/in/support/mobile-devices/why-the-heating-issue-occurs-in-mobile-device/
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
