wifi speed (very low approx 1/10) problem in samsung galaxy a 8.0 T295 model
(Topic created on: 06-11-2020 10:28 PM)
MurlidharBlr
Tablets
Hi,
I purchased recently two Samsung galaxy A 8.0(LTE) tabs model T295. This model have wifi speed problem. The speed shown by tab is 1/10 of actual speed. The other devices are showing ten time better speed than this device. Both the devices have the issue. For your kind information issue can be easily seen when wifi router enabled in 2.4ghz band.
I was not expecting such a basic issue with Samsung.
I am expecting the probable solution of the issue. If it software issue the fix it, otherwise document/publish this so that the individual should not be trapped.
Thanks,
Murlidhar
9811913528
3 Comments
Samsung_Support3
Tablets
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
1) Reset Network Settings: Go to apps screen >Settings >General Management >Reset >Reset Network Setting.
2) Restart the Router and Mobile Device.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Samsung_96usvGp
Tablets
I have same issue with tab t295 and i think it's Hardware problem suchlike wifi Antenna
Samsung_96usvGp
Tablets
Dear samsung team i have same models of samsung tab and facing this problem i tried to reset but problem is same and somebody told me that it's Hardware problem plz send me solution
