10-19-2023 02:48 PM in
PromotionsThe iPhone 15 Pro, the latest gem in Apple’s crown, promises an array of intriguing features, especially when coupled with the groundbreaking iOS 17. However, as with any technology, there are bound to be a few bumps in the road. One such hurdle that some iPhone 15 Pro users have encountered is the perplexing issue of having no call audio. This issue can manifest in different ways — sometimes, the recipient can’t hear you, while in other instances, you can’t hear them. If you find yourself facing these audio dilemmas, worry not. In this guide, we will explore a nifty workaround to resolve the iPhone 15 Pro no call audio problem on iOS 17. Follow along to get your phone back to its audio glory.
The iPhone 15 Pro No Call Audio Problem
Before we delve into the solution, let’s understand the problem. The iPhone 15 Pro, running on iOS 17, occasionally experiences a glitch where call audio doesn’t function as intended. You might be making a call, but the person on the other end can’t hear you, or vice versa. This can be quite frustrating, especially when you rely on your iPhone for clear and uninterrupted communication.
How to Fix iPhone 15 Pro No Call Audio on iOS 17
Now that we’ve identified the problem, let’s get down to fixing it. Follow these steps to resolve the no call audio issue on your iPhone 15 Pro:
1. Restart Your Phone
First and foremost, attempt a simple restart. Hold down the Power button until the Apple logo appears. Repeat this process three times before releasing it on the fourth attempt. Then, make a call and cycle the mute button on and off a few times. This may help resolve the audio issue.
How To Fix iPhone 15 Pro No Call Audio On iOS 17
- Tags:
- iPhone 15 Pro
10-20-2023 09:39 AM in
PromotionsDear Samsung Member,
As we have checked your concern is not related to samsung. So kindly share the issue or queries related to samsung then it will be helpful to us to resolve your issue in a proper manner.
