How to Enter Recovery Mode on iPhone 15/Plus/Pro/Pro Max
(Topic created on: 10-19-2023 03:16 PM)
Sandeep_Gautam
Promotions
In this comprehensive guide, we will walk you through the detailed steps to boot your iPhone 15, iPhone 15 Plus, iPhone 15 Pro, or iPhone 15 Max to Recovery Mode. This critical troubleshooting technique can be a lifesaver when your iOS device encounters issues such as unresponsiveness, crashes on startup, or gets stuck on the Apple logo. Recovery Mode provides you with the means to recover your device and resolve these problems effectively. So, let’s dive right in.
What is Recovery Mode in iPhone?
Recovery Mode in iPhone is a specialized state that allows you to recover your device when it faces critical issues, such as an inability to boot to the operating system. It also comes into play when your device crashes on startup or remains stuck on the Apple logo for an extended period. In this mode, you have two main options within the Finder interface:
1. Restore:
Choosing the “Restore” option will initiate a factory reset of your device. This process erases all data on your iPhone, returning it to its original settings. Unfortunately, there’s no option to back up your data in Recovery Mode, so it’s crucial to have your data backed up before attempting these steps.
2. Update:
Opting for the “Update” option, on the other hand, updates your device’s firmware to the latest version without wiping any data. This is a less intrusive option that can help resolve software-related issues while preserving your data.
How to Boot your iPhone 15/Plus/Pro/Max to Recovery Mode
Step 1: Trust your iPhone with your Mac
  1. Connect your iPhone to your Mac using the USB-C to USB-C cable that came with your device.
  2. When you connect your iPhone, you’ll receive a prompt on your Mac. Click on the “Trust” button and enter your iPhone’s password when prompted.
  3. Additionally, you’ll need to allow your device’s USB connection to your Mac. Click on the “Allow” prompt that appears on your PC.
  4. Open Finder, and you should see your iPhone listed under the Location section. Click the “Trust” button, confirming the successful connection.
How to Boot Your iPhone 15/Plus/Pro/Max to Recovery Mode: A Comprehensive Guide
cs_member10
Promotions
Dear Samsung Member,
As we have checked your concern is not related to samsung. So kindly share the issue or queries related to samsung then it will be helpful to us to resolve your issue in a proper manner.
