How to Fix iPhone 15 Pro Vibrate Not Working in Silent Mode
(Topic created on: 10-19-2023 02:50 PM)
Sandeep_Gautam
Promotions
The iPhone 15 Pro is a marvel of technology, offering a plethora of incredible features that enhance your daily life. However, no device is immune to occasional issues, and one vexing problem that has frustrated many users is the malfunction of the Vibrate feature when the phone is set to Silent Mode. In this comprehensive guide, we will explore three highly effective fixes to address this issue, ensuring your iPhone 15 Pro functions flawlessly in Silent Mode.
Fix 1: Adjust Sounds and Haptics
Step 1: Open your iPhone’s settings and navigate to “Sounds and Haptics.” Here, select “Always Play.”
Step 2: Scroll down and find “Text Tone.” Opt for “Haptic.”
Step 3: In this section, you have the option to either select a pre-defined haptic feedback or create a custom one.
Fix 2: Enable Vibration in Accessibility
Step 1: Head to the iPhone’s settings and select “Accessibility.”
Step 2: Scroll down and ensure that “Vibration” is enabled.
Step 3: Enabling Vibration in the Accessibility settings will override all vibration settings in the Haptic menu if they are turned off.
ReadMore: How to Fix iPhone 15 Pro Vibrate Not Working in Silent Mode
cs_member10
Promotions
Dear Samsung Member,
As we have checked your concern is not related to samsung. So kindly share the issue or queries related to samsung then it will be helpful to us to resolve your issue in a proper manner.
