br945
04-30-2018 01:50 PM in
Others
I am having serious issue of sound/volume in my Z4 device.
Have visited the service center who said that they have changed the settings to rectify the problem.
However, the problem is not resolved.
The ringtone, notification as well as media volumes are too low and cannot be heard even few meters away.
Is there something wrong with the Z4 model itself or something wrong with my device?
If the device is faulty and the fault cannot be corrected, it would need to be replaced.
please advise.
thanks
please advise.
thanks
2 Comments
admin_
04-30-2018 03:14 PM in
Others
Thank you for reaching out to the Samsung community! We would like to inform you that kindly once again visit the service center and submit the device for proper inspection and resolution. While picking up the device from the service center please check if the device issue is fixed or not and inform same to the service engineer.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
br945
05-03-2018 11:02 AM in
Others
visited once already. there was marginal improvement but i signed in good faith that issue was resolved. still volume not satisfactory.
will visit again and advise.
however, need reply to my specific query above, whether the Z4 model is known to have sound/volume issues? do later models have better sound/volume?
also please advise what is the function of the app called "volume" which is already pre-installed in the device.
thanks.
thanks.
