battery problem
(Topic created on: 12-10-2018 04:40 AM)
NKGA70
Others
I do everything for battery improve but on today I am very sorry to say that when I get Oreo after that battery drain so fast.i format my device about many times but problem not solve.
5 Comments
SageSummer
Others
Which phone.. Try to use the recommendation from Samsung.
Others
How to increase device performance.
posted by shiv
https://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=391013
Sachin-S20FE
Others
if u tell device model then I can post some useful tips you will amzae.
NKGA70
Others
c9pro
admin_
Others
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
