battery draining issue
(Topic created on: 09-27-2024 10:51 PM)
anupsingh12
Others
6 Comments
Others
It is recommended to utilize the adaptive power saving feature and reduce the Motion smoothness to 60 Hz.
goodthings
Others
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Others
Your's most welcome to here.
anupsingh12
Others
does it work
goodthings
Others
Try to it's. Thanks.
cs_member10
Others
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
