05-19-2021 09:19 AM in
OthersBrought F62 and get defective product which had serious heating issue. And replaced it from flipkart. Again the replaced product too has same issue of overheating.
This F62 heats on everything. Just on normal uses it get hot in upper area. When i measured it on IR thermometer the upper area temperature shows 42°c and in cpu z app it shows battery temperature 37°c.
What to do. Is this problem in all the samsung F62 phones.
Is thery any solution to this heating issue or i should return the phone.
05-19-2021 09:29 AM in
Others- Mark as New
05-19-2021 10:58 AM (Last edited 05-19-2021 10:59 AM ) in
Others- Then all the youtube reviewers are liers and may be promoted by the company.
05-19-2021 09:29 AM (Last edited 05-19-2021 09:30 AM ) in
Others- Mark as New
05-19-2021 10:58 AM in
OthersI did not found any Perf z app on google store
05-19-2021 11:00 AM in
Others- Mark as New
05-19-2021 12:47 PM in
Others- Mark as New
05-19-2021 12:49 PM in
Others- Mark as New
05-19-2021 03:54 PM in
Others- Mark as New
05-19-2021 04:11 PM in
OthersYou are right but in normal uses it gets very warm on the upper side of the device and gets uncomfortable to hold near the ears during calls. So i think brand should consider this.
