Fix battery drain problems on Android
(Topic created on: 12-04-2018 11:42 AM)
Raviijangra
Others
Check apps
If your battery is dying faster than in the past, see whether apps are using too much battery. You can force stop or uninstall problem apps.
Tip: You can’t force stop or uninstall Google Play services. Google Play services lets your phone use Google services.
Step 1: Restrict apps that use the most battery
Step 2: Force problem apps to stop
Step 3: Uninstall problem apps
2 Comments
admin_
Others
Thanks for sharing information with Samsung community!! Keep posting. Be sure to hit ♡ when you find an answer that works for you.
For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
sakshamnagar
Others
Nice post
