Battery drain issue on S23
(Topic created on: 06-13-2023 03:39 PM)
Afinn
Others
I am getting maximum of 6 hours of SOT in my brand new galaxy S23 is this normal ? Or can we get more SOT.Somedays i only get minumum of 4 hours. And any tips to improve the battery backup😊
6 Comments
Afinn
Others
Yeah sure👍
NOOB_1ST_ACC
Others
Also add almost all apps to deep sleep.
auditya
Others
SOT is not fixed. It depends on your usage, environment , temperature , also the network used like 4G, 5G or wifi.
If you only use wifi and use apps like social media then you can even get 8 hrs of SOT but if you use 5G and use maps with location on and other heavy apps you can get 4-4.5 hrs of SOT. So 6 hrs of SOT is normal considering the battery size of S23 which is only 3900 mah. Even I get around 5.5-6 hrs of SOT on my normal usage.
cs-member11
Others
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application>Support>Type your query>Ask a question/Tap an error report>Send)
Afinn
Others
Thankyou❤️
