Battery drain issue after update to ui7
(Topic created on: 05-21-2025 09:03 PM)
sjr000
Beginner Level 3
Others
Hi i am facing battery drain issue on my newly bought s24 ultra after the oneui 7 update ....
4 Comments
cs_member10
Others
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
sjr000
Beginner Level 3
Others
Its not a usual problem! Its all about your unstable update. The previous OS version are well optimized. I have no problems with that version. It is well optimized. After your one ui update phones get heated up frequently. My phone only 2 weeks old.
goodthings
Others
goodthings
Others
Your's most welcome to here.
