05-02-2020 01:24 PM in
Others- Mark as New
05-02-2020 02:03 PM in
Others- Mark as New
05-02-2020 02:26 PM in
Others- Mark as New
05-02-2020 03:18 PM in
Others- Mark as New
05-02-2020 03:20 PM (Last edited 05-02-2020 03:20 PM ) in
Others- Mark as New
05-03-2020 04:01 AM (Last edited 05-03-2020 04:02 AM ) in
Othersalso you can try wireless charging to charge fully(if you have one)
Also do a force restart once.
If anything doesn't work try re calibration of battery.
dail this in phone app
*#0228#
05-03-2020 09:21 AM in
Others
05-08-2020 11:09 AM in
OthersDear Samsung Member,
Please be assured and follow the given below steps to resolve the "charging issue":
1) Check charger functionality:-Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
2) Safe mode:-Power off the device > Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key.
Note :-To exit safe mode restart the device .
3) Reset the device: -Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Tap on Settings>Tap on General Management>Tap on Reset.
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
05-08-2020 01:33 PM in
Others
