Battery Drain
(Topic created on: 02-23-2025 02:35 AM)
kt888
Others
Ever since the one ui 7 update has come, the battery is draining very quickly. I had fully charged my phone at 11 pm and now my phone came down from 85% to 25%, below i attached a video , none of my apps is consuming extra battery, still the battery is draining fast.
5 Comments
Wodehouse
Others
hippocampus
Beginner Level 3
Others
S24 gets battery drain early in my device i bought this mobile recently
goodthings
Others
goodthings
Others
Your's most welcome to here.
cs_member10
Others
Dear Samsung member,
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
