wifi connectivity issue with s20 fe
(Topic created on: 12-06-2020 11:25 PM)
saurabh938
i am facing wifi connectivity issue with some apps like Netflix, Galaxy Wearables, etc....like when i open Netflix when connected to wifi, i wont open..but when i switch to mobile data, app opens...i have checked the Netflix app on other phone with same wifi, they run smoothly on those phones...
please suggest solution for this problem
11 Comments
Not applicable
sir , once go to General management settings then try to reset network section only ... reconnect wifi and check ✔
saurabh938
thnks for the raply...tried, but problem persists...plus the pathetic heating issue
Not applicable
from when you are facing that issues by the way ?
saurabh938
from yesterday..
Not applicable
then may be some network issues present... before sleep you can try safe mode just for query...let it run till morning
saurabh938
sure...how to switch to safe mode
Not applicable
press power button.... then when power off meny appear on display then long press on it ....it will immediately show safe mode option... click that just ..... and to turn off safe mode you can do that from notification Panel when your device running on safe mode
saurabh938
thnks for the info
Ehsank
try these steps and lets see
1. Forget all WIFI devices which were connected earlier.
Again turn on WIFI> Scan> and try to connect.
2. Reset network settings >Settings>General Management>Reset >Reset network settings)
