S20 Ultra Heating issue
(Topic created on: 12-06-2020 10:57 PM)
ashu14
Hi Members,
Anyone facing heating issue in S20 Ultra. Whenever I use camera app for 3-4 mins continously than phone starts heating up. Anyone facing similar issue. Just try using front camera for 5 mins or more and share your observations. @Admin I hope you yourself can check it
15 Comments
JashLathiya
May you installed some 3rd party camera app, that affects your system camera app..
that kind of apps are put much more load on camera for shutter speed and iso etc... that cemera sensor just heated up...
and because of so much heating, system close it immediately...
if you are using any 3rd party camera 📷 app... just uninstall it... if it was Cracked virsion....
and if you still facing issues... Go to SAMSUNG'S OFFICIAL SERVICE CENTER..
Thanks 👍
ashu14
Dear, I am not using any 3rd party app. And I have got this info from several users of S20 and they are facing same problem. Let me ask you, S20 ultra has 5000 mAh battery, as per you what should be the battery backup if you are using your phone in battery savings mode, keeping all apps in sleeping or Deep sleeping mode. Only 6-7 Hrs. And this is not with me. Every Indian version of S20 Ultra has this problem. If I use same settings and apps with US version having Snapdragon than there is 30% improvement in performance.
JashLathiya
When you bought your device?
ashu14
7 months old
JashLathiya
How Many hours you use your phone in Single day?
ashu14
Screentime is 4-5 hrs
JashLathiya
You may facing Problem of end of battery 🔋 Cycle... Your battery has limited number of charge and discharge...
after crossing that, your battery's health going to decrease and it was drained fast and also charged up fast... and also low health of battery has more resistance so it Heating while using and charging it..
you have to replace it...
and don't use your phone while charging...
at that time your battery also charging and discharging so it can affect your device's battery 🔋 health..
thanks 👍
Ehsank
first long press on camera icon >app info>storage >clear cache and data
Ehsank
2nd thing you can do is Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
if still same problem persist then do visit service centre
