shreyas
01-27-2017 12:01 PM in
where is fast charging options in s7 edge after nought update
7 Comments
Naren88
01-27-2017 12:09 PM in
battery-
advance setting-
fast charging
advance setting-
fast charging
shreyas
01-27-2017 12:13 PM in
thanks bro
shreyas
its little complicated after nought update to find options
Benz
01-27-2017 12:48 PM in
Not only complicated. The look and feel of samsung is lost. The S7 now looks like a Xiomi mobile. I hate this update. Anyway to get back the old look?
Om
01-27-2017 03:25 PM in
I love it though install it manually through odin
Vidyank
01-30-2017 10:27 PM in
Or just long press on power saving
On the top right corner press Advance Setting
Samsung_India_
01-31-2017 09:24 AM in
"Thanks for the query. Kindly go to Settings -> Device Maintenance -> Battery -> Options -> Additional settings -> Enable Fast cable charging option"
