Fast charging not working/ switching to normal charging
(Topic created on: 10-04-2025 09:09 AM)
Yansh0
When i plug in my s23 ultra to charge for a brief 1 or 2 second fast charging option will be displayed and then normal charging starts. This issue has been since the second or third update of one ui 7 and in every update while hoping to get fixed this issue still prevails. Previously even though frustrated i used to plug unplug plug unplug the charging cable until the fast charging is used. updated to one ui 8 stable build this issue is still there and im frustrated.
Before giving advise please note that i have already tried most of the things like inspecting the charger turning off fast charging then switching off device and again turning it back on wiping cache partition.
Instead of just spamming the so called fix for every issue please provide a real one. Im sure im not the only one thats been dealing with this software bug.
12 Comments
DGDG
Check your charger with any other phone. If there it supports fast charging, the fault is in the handset.
Yansh0
No issue in the device will try with new charger
Bejoy83
Check if fast charging is disabled in settings and also disable adaptive settings under battery. Check and let us know
Yansh0
Checked still nothing
Bejoy83
Did you try with a different fast charger?
Inspect the charger turning off fast charging then switching off device and again turning it back on wiping cache partition
Yansh0
Done still issue exists
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we kindly request you to share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve the issues.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
Members_8DdcRal
Beginner Level 5
  • I have same problem after upgrading my s24 ultra to Ui  8. Type C port not working properly, wired headphones can't be recognised, fast charging stops in seconds and switch to normal charge, also can't be charged when the phone is turned off. How can I report it Samsung developers?
