problem
(Topic created on: 09-06-2019 01:00 PM)
MAsSs0
I am having s10 plus..before the pubg performence was excellent..but now it is bad
5 Comments
I think you should clear ram and unwanted apps working behind simultaneously on backend while playing pubg
MAsSs0
no bro i not having any apps except insta fb and whatsapp
Deba1801
Instagram and Facebook are two most RAM suckers. clear them out while playing. Also do download the pubg resource pack.
graphic setting : you can play either at balanced extreme or hd extreme. you will be fine.
Maximums
Exynos processors are not comfortable for pubg game. I have also same problem.
[email protected]
Drop a mail to that and elaborate about you gaming issue faced on this issue.
