need help to fix my s10 display issue on my new phone
(Topic created on: 07-15-2020 11:49 PM)
sammya2j
My phone has automatically  changed to black and white phone ...when i take pictures  and send it to other phobe images  are in colour but in phone but in my phone the images are black and white...how do i fix this issue
9 Comments
Hi, go to Settings > Accessibility > Visibility enhancement > Colour adjustment > then check if the grey scale is on then turn it off, hope this will work.
sammya2j
did not solve the issue
Go to Settings > Digital wellbeing > Wind down, turn it off.
sammya2j
issue sorted thanks
sammya2j
my battery does not stay for one day
sammya2j
had taken the phone to service centre
sammya2j
phone is month old
Also go to settings > device care > battery > battery usage, there you can check the apps that consumed you battery in each of the last 7 days, there you can put those apps into sleep, also you can go to App power management, then switch Adaptive battery & Put unused apps to sleep toggles on, that will help.
MohammedSijah
Please click on 'Accept solution' from the three dots, if it helped you to solve the issue.
