i did not get oreo till now on my s7 edge .. any help please ?
(Topic created on: 06-14-2018 03:11 AM)
AhmedFerwana
i have not recieved android oreo on my s7 edge till now even it has been rolled out to my country two days ago ... any help ? 40583cc3-e4b6-41b5-93bc-0009358ae046.jpg
11 Comments
ahsantahir
UK Model?
AhmedFerwana
nope , UAE
clouds
I got the update yesterday here in UAE
AhmedFerwana
can you tell me thale way that i can use to get the update OTA knowing that i have two other devices (s7 edge ) which got the update today
try to restart your cell phone and connect to wifi and check for update!
AhmedFerwana
did not work
go to mobile setting >apps > click on 3 dot on top right corner >show system apps > search system update> click storages>clear data > then check for update >e1b9e317-4401-4e6c-8048-2061ea00b5a8.jpg
AhmedFerwana
same thing .. did not work
reuben
It's already come just check it again
