galaxy buds plus redeem problem
(Topic created on: 03-10-2020 08:08 AM)
Dave1
Guys i bought s20 plus and m having problem in redeem for buds from samsumg shop the otp is been receiving in another number not the actual one on which my phone was activated. Does anyone know what to do?
50 Comments
Mohitm
remove sim 2 and only try with the pre booking sim in Sim 1.
i have only started using sim 2 after i have redeemed my buds
Dave1
bro i have tried all the possible way still i am facing the same problem
ittopolis
Hi Dave1,
Is this issue of yours resolved ?
Mine is still latching on to the second sim
Dave1
is there any other way that might help me in solving my problem i mean any samsung support
Mohitm
remove samsung shop app and register again with pre booking sim in sim 1
also check with your dealer if he did pre booking for you.
lastly you can call the Samsung shop helpline number and register a complaint 1800107267864
Dave1
thanks bro appreciate it thanks
Mohitm
no worries, hope it works out for you....do update us....
Dave1
sure i'll update soon
iMonk
My friend had the same problem. What he did is that he put the sim1 in slot2, and sim2 in slot1. Now he is getting the OTP on his registered number.
