charging problem
(Topic created on: 05-29-2017 11:21 PM)
aerry
really annoyinf charging problem with s6 and s7 edge... charging from last 2 houra and it's still gone to 66% from 30%
7 Comments
swapnil
assumptions of power is more even the display resolution to fhd not in qhd
rishi12
broo i have faced this problem too
rishi12
goo to settings >about phone>software info(tap on build version 5 or 6 times)>then devloper mode would be on > tgen go back and open developer options >then go to usb confriguation >inside this tap on charging !!!!! put it on flight mode n power saving mode !!!! then charge !!!
aerry
ur soultion ia gud bro.. it made bit diffrnce in charging speed bt nt full.
n it's a temperarory solution..
thnks for ths
kabit
when you plugin the charger check if it say Fast Charging or Charging from USB.
aerry
it always says fast charging and shows normal charging time but take too much time to charge.. sometimes it moves 5-6% in 1 hour
admin_
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
