Yono SBI registration problem with e sim
(Topic created on: 12-16-2021 08:18 AM)
imshekhars
So I have two sims in my device sim 1 is my secondary and the primary one is in esim 1 slot. Now, after recent update to the yono sbi app I am unable to register from my primary sim that is in esim slot as yono app is not showing any option other than sim 1.
If you have any solutions please help.
PS: I have tries disabling sim 1 from dual sim settings but still it is showing only sim 1 option.
60 Comments
iamrohitkm
Same issue with me. Use yono lite app it will work. Please accept the solution.
nirmal1990
Beginner Level 4
Thank for you help, it worked
turbunator
Beginner Level 3
That's good done bro thanks
packiyaraj
யோனா Sbi அப் புதிய அப்டேட் வந்துருச்சு மறுபடி ஓபன் பண்ண முடியல ப்ரோப்லேம்
I have a better solution for using SBI Yono app without any flexing of muscles.
1. Open SBI Yono app.
2. Go for registration and then select sim one for registration. It will start 1:30 minute timer for waiting for confirmation.
3. Immediately switch to message app, there will be a no where sbi sending registration confirmation message. Copy the message and send the same message to same no with correct SIM.
4. Now switch to Yono app and Voila... the app will be asking for your account no to proceed further with registration.
aaryansbhati
Beginner Level 3
Thank you so much.
It's very effective
Samsung_6HPIGmM
Beginner Level 3
Thank you so much..this really worked.. I logged in my SBI account following these steps..thanks again!
pratikswain
Gpay phonepay chalega kya esim mai
ksbsingh
Yes
pratikswain
Gpay bi chalega kya esim mai
