Widget problem
(Topic created on: 12-31-2024 10:27 PM)
samsungexperrt
 can somebody tell me why the widget on the lockscreen for sunset or sunrise isn't it showing anytime? Please #samsung provide a solution
2 Comments
cs_member10
Dear Samsung Member,
We also request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
We're pleased to share that the recent issue has resolved itself unexpectedly. The widgets are now functioning normally again. Thank you for your patience and understanding throughout this brief period. Thanks for answering
