WiFi Connection Uncommon disconnection
(Topic created on: 05-09-2019 07:17 AM)
Pagz
Why would my S10 plus be disconnected or having hard time to connect to wifi on a certain distance while my other old phone are okay? (s8plus and J7) is there a problem with my phone?
2 Comments
yeah im facing the same problem with my s9 and its so annoying. still havent found a way to correct it
There is a live chat option available you can check out whats wrong with them and they ll tell you what to do. they helped me with the same issue as yours :)
