Why samsung apps using microphone anonymously without permission?
(Topic created on: 12-07-2021 11:17 AM)
heyitsmeSachin
S20 FE
I found that whenever someone is speaking or any sound is playing near my phone microphone is used by Samsung apps. Why?
@samsung
Not applicable
Google is always active even it is disabled.
This is not about google
I think Bixby is using microphone.. You can't even disable that.
Dear brother, send an error report to Samsung attached with this screenshot, to report goto "get help > error report (feedback section)" ... 👍
I'm sure you will get proper solution.. 👍
It's not an error.
Then send this on "get help > ask questions " section... 👍
Also try to disable microphone... 👍
BVikram
This is what my phone showing. From where you got that screenshoutScreenshot_20211207-115948_Permission controller_9466.jpg
sammy25
Try disabling microphone permission and check if apps work normally then.
They are working because you have given the permission while setting it up.
One UI, edge panel doesn't even have microphone permission
sammy25
In that case, send error report along with relevant screenshots
