Why samsung apps using microphone anonymously without permission?
(Topic created on: 12-07-2021 11:17 AM)
heyitsmeSachin
S20 FE
I found that whenever someone is speaking or any sound is playing near my phone microphone is used by Samsung apps. Why?
@samsung
23 Comments
MAHESAMSUNG
Go the App concerned and deny permission to the Micro Phone . Try.
shashidar
Wait for Android 12
All such nonsense will be informed immediately
You can't disable neither Bixby nor its permissions1639044367293_1639044367284_0.jpgSmartSelect_20211209-153412_Settings_57508_1639044252.jpg
cs-member13
Expert Level 4
Dear Samsung member,
Samsung has automated this process with a tool called the App Permission Monitor, which notifies you if any apps use permission that’s especially important or outside their normal operating range.
To turn off this feature, you can easily control turn off/on the app, and you can choose which app you want to be monitored.
open settings > lock screen and security > app permission monitor.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Ask question).
