While using instagram, S23 freeze suddenly and auto restart
(Topic created on: 3 weeks ago)
Deepu02
Whenever I'm using instagram or scrolling through reels. All of sudden my S23 get freeze and auto restart after some time. I can't use or swipe anything until it reboot. I see many other S23 users are also experience the same problem.
If anybody knows the solution it would be helpful.
4 Comments
rested_lion
Same thing is happening to my phone as well S23, it freezes while scrolling and crashes the entire OS and forces it to reboot.
If anyone knows a fix, please do tell. Samsung should push an update asap.
Meanwhile let's bombard them with error logs.
harshit00
Same with my S23 Ultra
cs_member10
Dear Samsung Member,
We would request you to kindly perform the following steps to resolve your issues.
● Galaxy device auto restart issue:
→ Kindly use a genuine Samsung charger.
We always recommend using a genuine Samsung charger for charging your device.
→ There are two methods to disable the auto restart function.
1- Tap on Settings> General management>Reset > Disable Auto restart (if enabled)> Auto restart disabled.
2- Tap on Settings> Battery and device care> Three dots> Automation> Auto restart at set times if enabled.
→ If you are facing this issue after installing any new application then uninstall that application.
Tap on Settings> Apps > desired app> Uninstall> Ok.
● Galaxy device Freezing issue: ● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third party application.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third party accessories.
● Kindly disable Power saving mode( if enable).
● You can reset your device by following the steps:
3. If you do not remember, then advise to reset (Forgot password) his/her Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
suren1021
same issue with my s23 ultra it freezes after sometime it restarts automatically
