10-23-2024 03:08 PM in
Galaxy S- Mark as New
10-23-2024 03:14 PM in
10-24-2024 08:44 AM (Last edited 10-25-2024 07:49 AM ) in
Galaxy SDear Samsung Member,
As per your concern, we want to inform you that the usage of the battery is different for every application, some apps consume more battery depending on the screen time, network fluctuation, refresh rate, etc. Kindly perform the following steps to resolve your issue by using the given links.
1. Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
2. Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
3. You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Compser> Select error report> select the appropriate issue category> Type your query and send.)
