06-27-2025 11:44 PM in
Galaxy SSolved! Go to Solution.
06-28-2025 01:10 AM in
Galaxy S1. Confirm USB Drive Compatibility
Format: Your USB storage must be formatted in FAT32 or exFAT. NTFS is not supported by most Android devices.
Try the USB drive on a computer to confirm it's working and formatted correctly.
2. Check Your OTG Adapter
Ensure the USB-OTG adapter or USB-C hub is functioning properly.
Try connecting another USB device (mouse, keyboard, different USB drive) to test the adapter.
3. Enable OTG Support
Samsung doesn’t show a clear toggle for OTG in newer models, but:
Go to Settings > Battery and device care > Battery and ensure USB devices can connect while on battery saver.
Disable Battery Saver mode if it's on.
4. Try File Manager App
Open My Files > Tap USB Storage (if visible).
Or try a third-party file manager like X-plore or Solid Explorer, which sometimes detects USB devices even when My Files doesn’t.
5. Check for USB Options When Plugged In
Connect your USB drive.
Pull down the notification panel.
Look for a USB notification: “Charging this device via USB” → Tap it and select “File Transfer” or “USB controlled by this device”.
If no notification appears at all, that’s a sign of a hardware or cable issue.
6. Restart in Safe Mode
Sometimes apps interfere with USB access.
Press and hold the Power button, then tap and hold Power Off > Choose Safe Mode.
Now try plugging in the USB drive again.
7. Update Software
Go to Settings > Software update and install any available updates.
Samsung frequently fixes bugs related to USB and peripheral compatibility.
06-27-2025 11:47 PM in
Galaxy S- Mark as New
7. Update Software
Galaxy STap the 3 dots on my reply and select "Accept Solution." Thank you 😊
06-30-2025 04:35 PM in
Galaxy SDear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
07-01-2025 05:21 PM in
07-01-2025 05:22 PM in
