USB OTG CONNECTIVITY ISSUES - S23 ULTRA
(Topic created on: 02-25-2023 11:24 PM)
mandeeprawat
I bought two S23 Ultra devices and a USB OTG (Type C) pendrive to backup data from old device. The pendrive connects well to one of my devices while it is extremely tight on my second device. There is no dust whatsoever in the port, it is absolutely clean.
5 Comments
Eaglett
The 2nd one must be a Virgin 🤣
mandeeprawat
cs-member11
Dear Samsung Customer,
Check by using other pen drive.
Perform interactive checks through the Samsung Members apps.
Path: Samsung members > Get Help > Interactive checks > Charger/USB).
Check by using genuine OTG cable.
Check whether device is OTG compatible or not.
To clear data of USB, please follow the below steps.
Setting > Apps > Three dots (Appearing at top right corner) > Show system apps > Search USB Settings > Tap on storage > clear data of USB Settings.
Please follow the below steps.
Settings > Apps > Three dots ( Appearing at top right corner) > Reset app preferences (It'll reset the permissions of all applications)
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Ask questions).
Thank you for writing to us.
Samsung Customer Support.
ramshan
Beginner Level 5
There isn't any option as USB settings in Apps settings page. Currently on One UI 6.1
Fttftt
Beginner Level 3
specifics does say Samsung Galaxy S23 have otg is that so?
