05-20-2024 09:46 PM (Last edited 05-21-2024 12:05 AM ) in
Galaxy S- Mark as New
05-20-2024 10:05 PM in
05-20-2024 10:26 PM in
05-21-2024 12:02 AM in
05-20-2024 10:35 PM in
05-21-2024 12:03 AM in
05-21-2024 12:04 AM in
05-23-2024 01:03 PM in
Galaxy SDear Samsung Member,
As per your concern, We would like to inform you that Samsung provides software updates to remove bugs and bring new features and more security to your device, and Super fast charging and fast charging both options are integrated into fast charging after the update. However, kindly perform the following steps to resolve your issue.
Galaxy device charging issue: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Kindly check if ''Multiple applications'' are running in the background of the device.
When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
