Samsung s20 fe 5g battery charging time
(Topic created on: 12-10-2021 05:39 PM)
Gowrishvenkatachalam
Guys my s20fe 5g times around 2 hours 30 min to full charge is it normal. At first I was able to full charge my phone in 1 hr 30 min. My phone is only a month old, so is it normal or what.
23 Comments
mahi1509
2h 30min is not normal.
Around 90mins is good
Chillmax
Can be because you turned off fast charging from settings or not using the original fast charger u got with the device
Fast charging is on and I am using samsung 15w charger which came along with the box.
Chillmax
Ok just see if it appears as fast charging when you plug in the charger with the screen on lock
Chillmax
As u can see it shows as written text if it's fast chargingScreenshot_20211210-180156_Samsung Members_77576_1639139518.png
Members_9HpRhPX
Use 25 watt charger. Company provides only 15 watt charger due to cross cutting while the phone support 25watt
Yeah it's showing as fast charging
Sid_Karna
Not normal..1 hours 30 min is normal.
Sáyân15
2hr 30 mins is not normal bro
Mine took 1hr 50 mins to charge from 0 to 100% from the included 15W charger
Recently i buyed the 25W Super Fast Charger
It takes 1 hr 10~15 mins to go from 0 to 100%🙂
